making a start
making a start
I made an appearance here a year or so ago, asking about altering bracing. I'm back to let you know that the input some of you offered has been incorporated in my design for a guitar. I have modified the bracing on the plans by Jonathan Kinkead to make his OM body guitar but with a short scale 12 fret neck - much like a Martin Norman Blake model. As I said back then, I was a bit terrified to mess with this, but I think it will be fine. A friend had given me some tools and a form for this body, plus a glued-up Sitka top, but I found the top to be maybe a little on the thin side (about .100 inch) so I put that aside for my first effort and started fresh. Synchronicity sometimes steps in at times like this, and I was told about the Vancouver Island Luthiers Guild show in October, and went to that. I talked to many helpful people (there are LOTS of folks making 12-fret guitars) and even bought some wood from a company I was planning to visit, saving me a longer drive and a little money. After a lengthy search I found a used 18-inch drum sander so am set to thickness as many tops, sides and backs as I have the energy for, if the first one goes okay. It will be a slow process, and I will be back with questions probably, but for a start, how do people feel about the ready made hide glue? Is it useful? What's the shelf life? Should I just stick with AR glue for everything? (I have just re-read the book about how Wayne Henderson built a guitar for Eric Clapton, but I don't think he will be beating down my door for this one, so maybe I don't have to be too fussy . . . ) At this point I have glued a new top and will start thicknessing and then a simple rosette, and then . . . .
Thanks again to all for helping to get this project underway -
Bruce Whittington
Bruce Whittington
Re: making a start
I have seen martin tops as thin as .095 . I build at .100 to .110 depending on the way it feels
Re: making a start
I haven't used the pre-made hide glue. I used hot hide glue for the blocks, top and back braces, neck joint and bridge attachment on the 2 I've built. I like using it, not too much trouble to mix and heat and I found the cleanup to be easier. I used titebond to join the plates, lining, top and back attachment, binding and fingerboard because I'm still pretty slow at those procedures. Please start a thread on your build. I also have a 14 fret om mold and a 12 fret 24.9 scale neck I would like to build with so I would like to learn from your build.
Re: making a start
The pre made hide glue is fine. It does have a shelf life that is shorter than most AR type glues. Franklin puts an expiration date on their bottles. It is also very easy to test, just put a thin smear on a piece of paper and if it dries hard in less than 15 minutes it is good to go.
Re: making a start
My understanding is that the "cold" hide glue is in fact nothing like hot hide glue. It's good glue, but definitely not "the same as."
Hot hide glue is, I have heard, much superior. I haven't had the personal experience to speak with much knowledge though.
Re: making a start
They are in fact the same glue. The difference is that the liquid hide glue has a chemical added to it to keep it in a liquid state and a preservative it from going rancid while it is a liquid.MaineGeezer wrote:My understanding is that the "cold" hide glue is in fact nothing like hot hide glue. It's good glue, but definitely not "the same as."
Re: making a start
They don't work the same. I don't think you can use the bottled stuff and expect the same results as you would get with hot hide glue.
