How to get a fade-resistant label
I've been working on the design for a label to go in my guitar when it's complete. It occurred to me that ink fade might be a problem. I hope, of course, that the guitar I build will be around for a while, and I'd like the identifying label to remain legible,
Have any of you addressed this problem? I'm thinking that printing a label on my home inkjet printer may not be the way to get a durable label. There a pretty good local printer who might be able to produce a durable label; I haven't inquired. Have any of you experience along that lline?
Re: How to get a fade-resistant label
Almost more important than the ink is the paper or linen used to print the label. The are archival quality inks that work with at least some epson printers. Combine the ink with acid free archival quality paper and the label should last awhile.
My labels are going on 100 years now printed on my computer and fancy parchment paper and they still look great.
I use a branding iron.
I printed the label in my OM build, using matte photographic paper and my printer. Most name brand home photo printers, like Canon, HP, etc. use fade resistant, archival ink.
I've got a lot of this paper, which I don't care for using with photos; if you want some of it, message me and I'll send you some of it.
I just came across this thread so apologies for a late reply. Be careful of inkjet inks - most will fade, except for those used in high-end photo printers. Look for acid-free paper in an art supply store if it is not identified elsewhere. The biggest problem may be with the ink you use to sign and/or number your guitar - they fade even before the printer inks. You can also spray the finished label (maybe even after it is in place) with artist's varnish that has a UV inhibitor in it. Gloss and matte are available. In the end, these labels are not exposed to a lot of damaging light, so may not be a worry, but in the picture framing business I have seen a lot of diplomas with faded signatures and there's no retrieving them.
I think I'll sign in pencil -- no fading! -- then spray over it. I was unaware of "artist's varnish." I'll look into that, thanks.
On the advice of a friend who is a vintage guitar repair wizard, I take my label to the local Fed-Ex store and they print it on a laser printer on archival paper. It is $1 a sheet, so you can get a bunch on there and it is pretty cheap. The laser ink is long-lasating and will not run with either dilute Titebond or dilute Hide Glue as an adhesive.
Ed MInch
Ed MInch
mnmusic
Do you have to bring the paper with you or does Fed-Ex actually have archival paper?ruby@magpage.com wrote:On the advice of a friend who is a vintage guitar repair wizard, I take my label to the local Fed-Ex store and they print it on a laser printer on archival paper. It is $1 a sheet, so you can get a bunch on there and it is pretty cheap. The laser ink is long-lasating and will not run with either dilute Titebond or dilute Hide Glue as an adhesive.
Ed MInch
The Fed-Ex in my little rural town of 4500 has the paper in stock, several colors and textures.
