Luthier Disk Question
mnmusic
My first guitar will be a 000 Martin kit from Blues Creek Guitar. What size disks will I need for this? I assume I'll need one for the top and a different one for the back. I plan on using a go-bar deck, if that matters.
Thanks,
Thanks,
Re: Luthier Disk Question
28 for the top, 18 for the back, I think, but get confirmation from Blued Creek.
yupper
here is a link to how to use them. The key is that the top is not totally radiused . We use it to create that 1 1/2 degree neck angle . here are 2 links to watch that may help
https://www.youtube.com/watch?v=LrgRKKsxL-M
https://www.youtube.com/watch?v=pz6xzVRA51E
the back is totally radiused. Hope this info helps
mnmusic
Thanks John. I've watched those videos a couple of times and will watch them a few more times I'm sure.
keiralucia
I agree that it would be the best if you take 28 for the top, 18 for the back. But if possible, you should go check this again
mnmusic
So John you do not carry the 18' disks, is that correct? They aren't available in the drop-down menu when I go to order the disks.tippie53 wrote:yupper
You'll want a 28' disk and a 15' disk. Not an 18' disk.mnmusic wrote:My first guitar will be a 000 Martin kit from Blues Creek Guitar. What size disks will I need for this? I assume I'll need one for the top and a different one for the back. I plan on using a go-bar deck, if that matters.
Thanks,
mnmusic
Thank you very much!tommyboy wrote:You'll want a 28' disk and a 15' disk. Not an 18' disk.mnmusic wrote:My first guitar will be a 000 Martin kit from Blues Creek Guitar. What size disks will I need for this? I assume I'll need one for the top and a different one for the back. I plan on using a go-bar deck, if that matters.
Thanks,
mnmusic
I got my disks and sandpaper from John today. I was wondering if I should seal the disks with a coat or two of shellac or varnish to keep them in good shape?
yes that is a great idea
