I am building a acoustic for a friend and for some reason he wants a black guitar. What is the best route to do it? I just started building this year and on the guitars I have built so far I have finished with French Polish.
Travis
What is the best way to "color" the body?
Re: What is the best way to "color" the body?
a few choices,
If you don't have a spray booth you may want to opt for acrylic auto paint
Does acrylic auto paint come in rattle cans?
Just spray on bare wood?
How many coats?
Is a certain finishing product necessary?
How many coats?
I have used it on electric solid bodies
I use a seal coat , then a base primer , depending on what effect you are going for you want to use under color , say white and put blue on top if it , or I like putting black under red .
There are many effects you can get. Experiment and you may be surprised . Then you want to clear coat . One nice thing about the auto finish is that you can be sanding it in a few hrs and it buff and polishes nicely. It dries hard and you don't need to use as much as if you used nitro.
It wet sands much the same , use 800 -1000 - 1500 2000 then buff and polish compounds. I really like playing with the meta flakes and translucent colors. That is where the under colors have the greatest visual effect.
You can also color shellac with pigments. I use Mixol pigments, they can be mixed with virtually any finish material. Though I have never done FP in a solid color I have done it in shaders.
