Fret Question
Dan Morris
Fret Question
Post by Dan Morris »
Can the frets be added to the fret board before it is glued to the neck or should it be done after the fret board is glued to the neck? (The neck has binding, if that makes any difference.) I was going to insert the frets before gluing the fret board the neck and I've seen advice on both methods, so I believe either would work, but I'd like to do it with the fewest potential complications.
Re: Fret Question
I always fretted my FB prior to mounting the FB to the neck, but I'm no expert and others do it the other way. Wait and get some advice from some of these folks who really know what they're doing. You may find that you want to try it both ways and see which one you like best.
Re: Fret Question
the best guitars that I made were fretted after the neck was set and the fretboard trued to the guitar. If you fret the board first you can only then work the frets. If you can't get the fretboard trued you have to remove more of the fret.
The lowest action I have made had a 1 1/2 2 action without buzzing. This also reduces the fretwork time.
I also glue the fretboard on the neck against a granite surface plate so the neck is a dead flat as possible.
