Swirl remover
Re: Swirl remover
Glazing is the process of rubbing out the swirls. I have used lots of polishes over the years. Martin Senour's swirl remover was a favorite for a while but i have used some from 3M, Novus and others with good results. My latest favorite is something I make myself by combining a few different compounds and thinning them out for hand use with a cloth or felt block. If you are interested , PM me as I do sell small bottles of it.
Re: Swirl remover
I had found 3M hand glaze pretty good.
Re: Swirl remover
Maybe i am doing this wrong.
I buff with the mazerna's and thrn use swirl remover and a wizards was.
Is the trick to rub it in and not let it dry?
It dries fast and is hard to remove.
Re: Swirl remover
yes keep it wet
Re: Swirl remover
I use the cheap 3 dollar cotton buffing wheels from Harbor freight. I dictate one per grit (medium, fine, swirl, all menzerna). Swirl remover always gets it's own wheel, if not a new one. They are cheap, and essentially disposable. I keep them in freezer bags (quality zip locks) to try to keep them clean and safe.
The wheels go in a drill, and so you can a pretty good buff with out using any upper body ;)
Re: Swirl remover
Thanks Dan.
RG
RG
