Swirl remover
watergunn
Swirl remover
Hi guys.
I had a question regarding swirl remover.
I usually buff on an arbor with the Manzerna medium and fine compounds. Then i use a swirl remover.
My question is do you wipe it on and buff it off or do you just wipe it off with a rag?
Not really sure I am accomplishing anything just wiping it on and wiping it off!
Do you apply it directly to the buffing wheel?
Rick Gunn
Rick Gunn
Re: Swirl remover
I like to wipe it on with a soft rag and use light pressure
watergunn
Re: Swirl remover
So no buffing at all with the machine?
Re: Swirl remover
sure just be lite
Re: Swirl remover
If you use the buffer for the swirl remover, I think you should be sure you have buffers that do not have the other grits of compound on, basically buffers only used for the swirl remover,watergunn wrote:So no buffing at all with the machine?
watergunn
Re: Swirl remover
Yep. I have a dedicated "clean" wheel I use to just buff wax off the guitars when I clean them up.
The issue I am having is the swirl remover dries so fast doing it by hand. I was just wondering if it should be put on the wheel itself.
Should I be using an extra fine Mazerna instead?
RG
RG
Re: Swirl remover
I use a rake when I change the grit
the best advice is to do it and see what you get.
You learn by doing don't fear the mistake fear not knowing
Re: Swirl remover
well, that would makes my life easier.tippie53 wrote:I use a rake when I change the grit
B. Howard
Re: Swirl remover
I do a final hand glaze with a felt block & some polish to remove swirls.
watergunn
Re: Swirl remover
Can you tell me what the glaze is and the polish?
Thanks Brian
Thanks Brian
