Sap?
aaron
Sap?
Hello all! I've been finishing my second guitar this week with tru oil. The back and sides are Rosewood and the top is spruce. The challenge I have come across is that for the most part the finish is looking great except there are some places on the sides where it looks like Sap or something is coming through. The finish resists it and it is a little sticky even. What should be done?
Re: Sap?
what kind of wood ?
B. Howard
Re: Sap?
Must resins and sap can be cleaned off with DA. You may need to scrape back the finish around it a bit to clean it up at this point.
Re: Sap?
DA Denatured Alcohol
aaron
Re: Sap?
Thanks guys. I may try the DA route. Should I just rub it on the trouble spots or is there a more effective technique you have used?
John, the wood is rosewood. And the problem areas are only on the sides, not the back which is also rosewood.
Re: Sap?
it is not unusual for rosewood to emit a resin during the bending process. While this normally is sanded off , there may be condensed pockets. I would just clean up the bad area and see what it looks like.
mjmeehan
Re: Sap?
I had a similar problem with tru oil over rosewood. I found it necessary to sand back to the wood, apply a layer of shellac, then proceed with the tru oil. It worked well and I have used this process many times since.
I figured that the tru oil didn't cure fast enough over oily wood and allowed the oils to mix. The shellac formed a barrier between them. That's a guess, though. All I know for sure is that it worked. Good luck.
glasalle1
Re: Sap?
My method for Tru oil is:
- Pore fill with Z-poxy
- Seal with Shellac
- wipe Tru Oil on thinly with the grain
- Wipe it off with the grain
- Put on 12-15 coats (up too 2 coats a day)
- if required, I "level sand" with 0000 wool every 4 or so coats (gently!)
- when done, let cure for 2 weeks
- Buff out with Micro mesh from 3000 thru 12000
- hand polish Meguirs swirl remover
- Meguirs #7
Glenn
- Seal with Shellac
- Meguirs #7
Glenn
