For those interested, I built a concert ukulele from plans provided by Don Morris (the website is www.donsplans.com). The plans were pretty straightforward, except for one thing: the scale length is listed at 15.5" (394 mm), but the plans actually show an instrument with a 15.125" (384 mm) scale length. There are no dimensions given for the instrument itself. I decided to go with the actual scale length, since moving the bridge might have affected the acoustics, and took all the dimensions straight off the plans.
The plans called for a glued dove-tail joint, but I chose instead to bolt the neck on and modified the plans accordingly.
Since there was no soundhole reinforcement, I cut out a piece of linen to fit between the soundhole braces, saturated it with glue, and glued it in place.
I used kerfing, which the plans recommended. Since they recommended using the smallest size available, I sawed regular guitar kerfing to half the depth it came in.
Note that the fingerboard is a little less than 1/4". I used an old ebony guitar fingerboard (rejected because of a crack on one end, but I didn't use that end for the uke) and had to remove about 1/8" to bring it to the dimensions on the plans.
Although the plans didn't call for any neck angle, I found after assembling it that a negative neck angle (like that found on a classical guitar was necessary to avoid using an unnecessarily high saddle. It isn't much ... maybe half a degree. I suppose I could have avoided that by removing even more material from the fingerboard, but re-setting the neck was easier due to the bolt-on joint. Also, there is no truss rod in this instrument, so I wanted to keep the fingerboard as thick as possible to increase the stiffness in the neck.
As for the tone of the finished instrument, it's a bit thinner than other concert ukes I've heard, but the soundbox on the Don Morris uke is much smaller than on those other instruments. It'll do for a travel instrument, but if I had to do it again, I think I'd use other plans, or at least increase the size of the soundbox.
Don Morris Concert Ukulele
JLT
Jump to
- Bending Library From Blues Creek Guitars
- General Information
- ↳ Building Tools
- ↳ Guitar Building Procedures
- ↳ Wood and Tonewoods
- ↳ Finishing Your Guitar
- ↳ Reference Library of Guitar Tops
- ↳ Restorations and Renovations
- ↳ Guitar Setup
- ↳ Guitar String Reviews and Discussion
- ↳ Repairs
- ↳ Special Guitar Tips
- ↳ Blog Your Project
- ↳ Show It Off!
- ↳ Events
- ↳ New Members Introductions
- ↳ Local Luthier Networking
- ↳ Photo of the Day
- Building From Scratch
- ↳ Guitars
- ↳ Ukuleles
- ↳ Mandolins
- ↳ Other Instruments
- Building From Kits
- ↳ Beginners' Questions
- ↳ Kit Guitars
- ↳ Kit Ukuleles
- ↳ Kit Mandolins
- ↳ Kit Electric Guitars
- Reference
- ↳ Reference Materials
- Tutorials
- ↳ John Hall's Quick Tip Videos
- ↳ DVD's and VHS
- ↳ Books & Magazines
- ↳ Online Tutorials
- Trading Post
- ↳ Guitars and Guitar Parts
- ↳ Lutherie Books and Magazines
- ↳ Lutherie DVDs and Tapes
- ↳ Lutherie Tools, Jigs, Molds
- ↳ Wanted to Buy or Trade
- ↳ Bargains
- Everything Else
- ↳ Anything Else
- ↳ Forum Software Questions and Answers
