Hammering frets
Woody OKeefe
Hammering frets
I just finished hammering the frets on my second fretboard. Fortunately I watched John Hall's tutorial on you tube and eliminated the problems I had on the first. Thanks John. It went so smooth, I thought I was doing something wrong! Plus I saved $162.00 Because I didn't buy the fret press.
Thanks again John.
Thanks again John.
mjmeehan
Re: Hammering frets
Great to hear! Personally I like hammering frets, one of the most straight forward parts of a build.
Re: Hammering frets
Yep - our Arbor press and brass cauls just sit in the corner and gatherring dust --- Hammering is very quick once one gets the feel. I use a large hammer now. I cover the head with several layers of heavy adhesive back metal foil tape used for furnace installions. That provides a padded surface which is easily replaced --- those tiny nylon headed hammers are not for me -- I want something that can wack those babies in with ease!
Freeman
Re: Hammering frets
Since I started using a fretting caul in a drill press I've had to do very little leveling and dressing afterwards, certainly not nearly as much as I did when I hammered them in. Probably the only guitar I would consider hammering anymore would be a Spanish heel, I don't see how you could support the fretboard extension. Otherwise its press, baby, press.
Obviously milage varies.....
Re: Hammering frets
If you fret the board before gluing it to the neck you don't need to support the extension.
Re: Hammering frets
Ditto --- Tony
But, actually Bob Taylor has an invention, I think still sold by LMII called a "Fret Buck" mainly for repairmen -- its supports the FB extension area.
Re: Hammering frets
Gee getting hammered ? I never did that , LOL
Re: Hammering frets
I use my drill press as the arbor, and a brass caul.
Mainly because: I don't have fretboards all over the place to practice on. A slip of the hammer and I'd be whining to Ken Cierp to overnight a fretboard.
A number of things the pros can do are because they have done it a LOT. For us kit builders, what's the hurry? I can press in all the frets in 15 minutes or so with little chance that I will screw it up. And the touching-up is easier, too.
I don't like to learn things on the guitar I am currently working on. I want the skill developed before that. The fret pressing does not take the skill, very little learning curve.
Whatever works for you!!
DaveB
DaveB
Re: Hammering frets
I have to admit, I personally prefer the fret press over hammering when I have the choice. It's just a bit easier to do clean consistant fretting for me. Generally only have to level for maybe 1-2 mins when I use a press, and 50% of the time don't need to use my crowning file at all.
Harbor freight has arbor presses for pretty cheap, like 20 or 30 bucks or something like that, and then you just get the attachment with cauls from stewmac and it saves a bit of coin.
Re: Hammering frets
You can use a drill press too, right? Like even a table top drill press, with the attachment?
