bending fret wire
Datrek
bending fret wire
D you bend fret wire by hand or do you use a machine?
Re: bending fret wire
Here's a great starting point for fret wire bending:
search.php?keywords=bending+fret+wire&t ... mit=Search
-tommy
-tommy
I get mine from a supplier who sells it pre-bent in a coil.
I also get the coils and have not had to bend wire.
I have a little bender that I made. Very simple to tighten the radius to help hold the ends down. Hand bending can put kinks in it. I also use the prebent stuff and sell it. That is fine for most applications. On refrets you may need a touch more.
B. Howard
I like the stuff on coils but when i use sticks I have a notch cut in the edge of my bench that I pull the wire through and bend it. The inch or so at each end stays straight but it is easy enough to do.
