Question about clearing neck mortise
geoawelch
Post by geoawelch »
Working on my second build - a Blues Creek D35
Am ready to glue on the soundboard, but need to clear the neck mortise prior to gluing. It's a bolt-on neck.
Was wondering what methods work best for you folks for removing rim material to clear the mortise?
Thanks,
George
Re: Question about clearing neck mortise
I use my inlay tool but you can also use a flush bit in a router a dremel and a sharp chisel .
geoawelch
Post by geoawelch »
Thanks John
Tom West
Post by Tom West »
I don't clean up the mortise till after the top and binding are done. Then a Zona saw to get an opening and a flush cut router bit.
Tom
geoawelch
Post by geoawelch »
Thanks Tom,
Also heard offline from Ken Cierpilowski who advocates the same thing.
Now that I recall the first build (eight years in the past!), there was an issue there.
George
Many don't open the joint till you are done the finish as it allows using a power buffer without grabbing the edge.
Tom West
Post by Tom West »
tippie53 wrote:Many don't open the joint till you are done the finish as it allows using a power buffer without grabbing the edge.
John: Thanks for that...................never occurred to me to do that....!!!
Tom
