Fret Leveling
Fret Leveling
Every article, thread, etc. I see about leveling frets before dressing uses a flat leveler (file, board with sandpaper,etc). What is wrong with using a radius block with the same curvature as the fretboard?
Re: Fret Leveling
you may find that you will have more accurate results using the flat and working with the line of the strings. I have a set of radius blocks and got the best results when I started using the flat leveler.
It sounds like a great vid shoot.
