Fishman not working properly
Zen
Post by Zen »
Has anyone experienced a problem with a fishman pick up not picking up the high E string properly? The saddle slot seems to be completely level so thats not the problem, but I notice the end of the pick up strip is slightly frayed--the copper wire is slightly parted and you can barely see a wire underneath--at least it looks like a wire. Having said that it does'nt look damaged as such. Its the B Band T35 system on a Walden cs500 CE
RUSTY
dwd811
Re: Fishman not working properly
Post by dwd811 »
I have had that problem twice, but it was with the Hige E and B strings. On the first one I corrected it by flattening the saddle, but on the second one, I ended up having to get a replacement pickup element from Fishman. They were very generous that day and shipped me one at no cost. Good luck.
David Delcambre
Picayune, MS
Look for something that is under the pickup a small piece of wood chip , anything. Most of the time it is not seated and your saddle is off the pick up.
Another reason not to use under saddle transducers . I switched to K&K , They are a better pick up and you don't have to worry about the saddle .
+1 for K&K. Only type I install and everytime I put one in I get the "WOW" factor from the new owner.
B. Howard
Post by B. Howard »
K&K pure mini gets my vote for best pick up you can put in an acoustic guitar.
