removing neckblock?
dwd811
removing neckblock?
Post by dwd811 »
I am on my first build - I dont know how butI got the top to side angle wrong at the neck- it's around 92-93 degrees and I can only pull it so much - has anyone had to heat the neck block to remove in order to remove it to correct the problem? Is it even possible? The back is not installed yet. Should I just start over?
David Delcambre
Picayune, MS
CavalierKingCharles
Re: removing neckblock?
Post by CavalierKingCharles »
I'm thinking a shim under the fret board extension.
I would first fit the neck and see where the neck ends up. The neck needs to be sloped so that a straight edge on the neck face without the fret board is about a 1/16 inch off of the top at the saddle location. Do not adjust the neck to the top. At that point you can see what is going to happen with the fret board extension. If it is really just angle at the block, not the entire upper bout a shim may work.
The last thing I would do would be to try to pull the block. To pull the block you need to first pull the top as the rim would also be sanded down and would need to be fixed.
this isn't that bad You would want to see about 91 1/2 degrees
you set the neck to the body , look at the sides and the lines at the bouts. When you set the body vertical are these planes matching or is one bout out of line with the other?
I never take the guitar out of the mold until the top and back are glued on. You really want to keep things in alignment.
I am sure you can make this work , it is all part of the learning curve. You learn more from mistakes than success , so in reality mistakes are learning opportunities.
Dave Sayers
Post by Dave Sayers »
If the back is not installed you may be able to make adjustments as you go.
dwd811
Post by dwd811 »
Thanks Mr Sayers....Yu were right - I amde a small adjustment when I glued on the back and all seems well - I'm quite pleased actually. I appreciate the feedback from all of you.
David
David Delcambre
Picayune, MS
