These TOGGLE clamps screw on and off my hardboard build sheet easily. A great jig for chiselling the ends of the braces. Thank you whoever you were that gave me the idea. These clamps came from China and were dirt cheap/http://www.ebay.co.uk/itm/360545394672? ... 1497.l2649
I should add that I put a piece of suitably sized softwood under the end of the brace I am thinning to support it. I also use a fine diamond stone to sharpen the chisel every so often. Seems to work.
I don't know what luthier gave me this idea but many thanks.
Dave Sayers
Re: I don't know what luthier gave me this idea but many tha
Filed away for future reference. Thanks.
-tommy
-tommy
I like it... could be integrated into your radius disk (if you use one) to avoid needing to shim the end of the brace.
Dave Sayers
Imagination is all it takes.
Dave Sayers
Yes it could.darren wrote:I like it... could be integrated into your radius disk (if you use one) to avoid needing to shim the end of the brace.
