how to pull a neck
how to pull a neck
one for learning to take out a neck
hope you like
Re: how to pull a neck
Thanks, John.
This a great video. Too many videos do not show how long and how patient one must be This one does a nice job of staying with it from start to finish. I have a neck that I want to reset and have been a bit afraid. I still probably have a couple of years but maybe I will give it a try.
thanks
we want this place to have good information . I also keep the comment button on so you can make suggestions and comments.
We are here to help
Another nice video John. For anyone that may be interested, I have a StewMac steam needle and use a #46 bit to drill the steam injection holes.
I have the same needle and use a 1/16 bit , In my old days I used a air inflation needle.
I have seen the steam rigs made from cappuccino machines, It really doesn't matter , steam is steam. Be safe as a steam burn hurts.
Post by nkwak »
Thanks, John. Very informative. Is this process only for AR and hide glue though?
You mentioned that this guitar was getting re-topped. I'm assuming it's the same one that you put an Adi top with 1937 bracing on? Do you have a video for the re-topping too?
The reason I'm asking is that I want to retop my old lawsuit Tak. Problem is that the neck joint is epoxied together now.
Epoxy won't steam out. In fact you will have a most difficult time.
If I have to cut a neck out I will take off the fretboard , then sometimes you can drill out the neck and make a new neck.
I have removed 1 epoxied neck and I won't do another.
Post by nkwak »
tippie53 wrote:Epoxy won't steam out. In fact you will have a most difficult time.
IIRC Freeman recently sawed off the neck on his of his old Yamaha which was epoxied on. He cut through the neck joint and bolted it back on. I'm thinking that that will be the route I take with my old Takamine, which I plan on retopping.
That actually works very well. Use a flush cut Japanese saw to get through the neck.
Yes
that is about the only way to get it. I should have mentioned that .
