So are you saying that even if the fish glue will fill a gap, it is a weak one? I suppose that could be because it is more brittle and less flexible than Titebond.tippie53 wrote:I have no idea why it doesn't smell , I guess the process must render that out. As for gap filling a gap and maintaining adhesion is a different thing also a glue line of a few thousandths is normal filling a larger than .010 gap renders the adhesion less effective than tite bond.
Update on the Glue study
Re: Update on the Glue study
That is not what I am saying.
In a bad joint titebond will fill a larger void.
Without question, when you are building a guitar you want your joints as perfect as you can make them.
The more sloppy you are the less efficient the guitar will be. Fish and hide glue are much harder than titebond.
Don't rely on glue, rely on the joinery, the better the joint the more efficiently the vibration will move through the body.
I know about tight joints, I am just trying to understand how tightbond is better at gap filling. I took a drop of fish glue and let it harden, it stayed pretty much the same size. I will do a comparison now to see which glue shrinks the most.tippie53 wrote:That is not what I am saying.
It does have a distinct odor, though. The first thing I thought when I started using it was, "Hey! I know that smell!" It was the same glue that used to come in those little bottles with the flexible rubber caps, back when I was a sprout (more than fifty years ago). I don't know if it's available any more, or whether it's chemically identical to the stuff we're using for instruments, but it sure smells the same.watergunn wrote:Thanks for the update.
Also, my son wants to know why fish glue smells nothing like fish!!!!
Speaking of gap-filling, I've had problems with some joins, particularly on repairs. I use a mixture of glue and sawdust to pack the joint, figuring that the sawdust will give the glue something to stick to besides itself. I suspect that it isn't as good as a properly fitted joint, but it seems to me that it's got to help a little bit.
Sounds good so far John.
Did you run tests on the wood to determine the mechanical properties before hand? It's not too hard to get the Young's modulus and damping factors to within a reasonable tolerance. May or may not be useful info, but what the heck.
Titebond creeps less than some other similar glues. I have to wonder if that creep has any bearing on damping in the glue line.
I remember those days with those bottles of glue too. I get flashbacks when I sniff the fish glue, they are just not psychedelic. I do the same with gaps. I will sand some of the same wood I am gluing with fine sandpaper, then mix with glue, it works great. But of course it is no substitute for proper fitting joints.JLT wrote:It does have a distinct odor, though. The first thing I thought when I started using it was, "Hey! I know that smell!" It was the same glue that used to come in those little bottles with the flexible rubber caps, back when I was a sprout (more than fifty years ago). I don't know if it's available any more, or whether it's chemically identical to the stuff we're using for instruments, but it sure smells the same.watergunn wrote:Thanks for the update.
The more you build and the better your technique gets , the better the end result.
David Musselwhite is retired CF Martin repair dept and many may know of him. We had an interesting discussion about the 30 era guitars and his statement was
" Did anyone ever think , that at this period people were going through a depression . The elite employees were kept , and they did very good work. So maybe it was the construction by very good technicians that made a difference of this period. "
That statement does make a lot of sense. Figure the employees were not just good but appreciative that in a time of want , they had a good job and steady income , so the strived to be the best they could.
Ludicrious and insulting – to all craftspersons around the world. Real artists will and have worked work for nothing!!
this is a statement about CF Martin guitars not artists. It does make sense. yes artisans will do what they do because it is what they do. This was considered a golden age for CF Martin and it makes sense to a degree. The statement was in no way meant to be defamatory but a simple observation.
That paste was made from anchovies. I remember that paste too John. It was always a supply requirement for the primary grades.JLT wrote:It does have a distinct odor, though. The first thing I thought when I started using it was, "Hey! I know that smell!" It was the same glue that used to come in those little bottles with the flexible rubber caps, back when I was a sprout (more than fifty years ago). I don't know if it's available any more, or whether it's chemically identical to the stuff we're using for instruments, but it sure smells the same..watergunn wrote:Thanks for the update.
