African Mahogany for neck and end blocks
See any problem with using this wood as long as its quarter sawn with the orientation correct?
Re: African Mahogany for neck and end blocks
it is a great wood.
use it
use it
I'm using it now for the first time. The additional weight over Hog is probably negligible.
I prefer the African, I find it more consistent as far as density when compared to Honduran.
I purchased a 3/4" x 8" x 36" long board, quarter sawn. I could use it for a couple of necks, end blocks, kerfing,
not quite wide enough to resaw into a b & s set unless I got really good at resawing.
It has nice ribbon figure.
A word of caution if you will be carving necks from it. That nice ribbon figure will most likely contain a complete reversal of the direction of the grain in each alternating stripe which can make carving a bit more challenging. In that regard most Bigleaf Mahogany is a bit easier to work. That said, I love it, it's what I have been making my necks from.Kevin Sjostrand wrote: It has nice ribbon figure.
Brian, would you say that a rasp and working through the sandpaper grits work much better than carving with edge tools?
A rasp can grab a bit also unless it is used exclusively across the grain but it could be a bit easier. I still use my spoke shave, I just reverse the cut on the figures. I push away from me or pull towards as needed. The key to using edged tools on figured woods in general is keeping them surgically sharp and taking light cuts.darren wrote:B. Howard wrote:
