Neck Set Shim Go Bars
Here's a neat little trick I picked up. If you do neck resets or get to a point where you need to add shims when fitting the neck, this is a great way to get the shims glued in nice and tight. This is a neck reset I'm doing on a 1967 Silvertone/Harmony Sovereign.
