Documented 1931 Martin OM 28
Tops only
Locked
this is a top that was pulled of a 1931 OM. The bridge plate was a replacement from the factory. The photos may not show the notch from the old plate. The drawing will show the landmark points . The width is actually 15 1/16 and the binding is also removed. The actual width was 15 3/16 with the binding at the lower bout.
Re: Documented 1931 Martin OM 28
thanks for that John! Very educational.
What an ugly bridge plate replacement! <smile> I'll bet the original wasn't near that large. Was this done to strengthen a problem area on the top?
I have no idea why that was put in , other than that was what they used at the time of the repair. In the old days , a repair was done that more matched the time of the repair technique than the original construction.
longbow
Post by longbow »
Thanks John, Those finger and tone bars come right up to the kerfing. They didn't go inside the rim ??? Just checking some guys do put them in like the X-braces..Very cool pic's..LB..
the only braces in the top that go into the kerf are the transverse and the X braces The top thickness .109under the finsh
longbow
Post by longbow »
Thanks again, very neat to know small things they did in 1931.....109 top thickness huh..one more bit of info.. I love this post...LB.
John, how far out from the x-brace are the peaks of the first nodes on the tone braces?
1 7/16 from the X to the top of the first node
this is a good thread and needs to been looked at again
thanks
Locked
