cutting ramp in slotted headstock
Tim R
All,
I have a neck with a pre-slotted headstock, but the ramp, or angle, at the front and bottom end of the slots has not been cut. What is the right tool for this? I suppose I could start with a rat tail file and then finish using a dowel with sandpaper on one side, but I don't want to use the wrong tool and risk ruining a good neck. Suggestions...
Thanks,
Tim
Thanks,
Tim
chimpotle
Re: cutting ramp in slotted headstock
Rat tail file is what i used, and i got that advice right here. No complaints from me!
- Chuck
that is what I use
Tim R
good enough for me then! Thanks.
I clear out the bulk with a 1/4" chisel and then work the profile with a section of 1/2" steel (actually a broken long 1/2" drill bit) with progressively finer sand paper wrapped around it. Just sanding takes too long, and I've never been able to find a 1/2" round file locally...this is pretty quick. I saw someone else putting a screwdriver through the tuner hole to set the angle and it works great. I tried tape to protect the wall of the slot -but it only lasts a short time before your file or sandpaper bites through it.
A right sized carving gouge might save a lot of sanding.
-tommy
-tommy
How do you guys determine what angle to use?.......or is there a commonly used standard?
Any standard would depend on your headstock angle and nut placement.Darryl Young wrote:How do you guys determine what angle to use?.......or is there a commonly used standard?
Use the screwdriver in the tuner hole and place a straight edge on that and your nut height (remember your nut slots will be a skosh lower)... there you've got your angle. No reason to make it more complicated.
However... don't just check for clearance straight to the nut... the E/D/G/e string clearance is what you need to be more concerned with.
