new rosette
new rosette
here is a tile rosette I did this by placing the tiles on a backing , set them into the rosette then spilt it with the circle cutter and glued it in , then opened the split and dropped in a pearl rosette into the tiles
Re: new rosette
very nice, how wide is that?
Re: new rosette
Nicely Done! Kind of ironic but I just finished with this one..A little Koa and Abalone design I am using on a cut away OM model with Koa bindings. The other rosette is a Cocobolo cut from a solid piece instead of using segments like I did with the Koa.
Re: new rosette
the rosette is .250 on the center 3/32 on the inner and outer rings
