I was looking at the guitar I built for my daughter almost 2 years ago and noticed it had high action. Examining the guitar I noticed the heel lifted slightly. No big deal I loosened the strings, tightened the bolts and everything went back to normal. It also gave me the opportunity to clean it up and change the strings.
I am sure that the neck loosened from shrinkage of the neck block from either environmental conditions or as it aged. My question: is this normal behavior for a guitar with a bolt on neck?, fixed with semi regular maintenance?
Thanks for any insight.
Bolt on necks and age.
Tom West
Re: Bolt on necks and age.
John: Have never had this problem. You could use bellville cup washers if it is persistant.
Tom
Tom
yes
this is very common with the bolt on necks. Even with compression washers.
