New neck for a Martin OM kit
segovia
Post by segovia »
I bought an OM kit from JH a while ago I have assembled the body and I am now ready to join the neck to the body. The neck is a bit too thin at the nut for my playing style so I was contemplating making a new neck from scratch. This will benefit in two ways as I get to practice neck making I get a neck of the width I desire. It's a dovetail neck joint, what are the chances of matching the new dovetail with the existing pre cut neck block ?
J
Re: New neck for a Martin OM kit
practice with some poplar from home depot and I bet afer 3 necks you will have it down
Jim_H
Post by Jim_H »
I think there are some tutorials on carving a dovetail by hand, using hand tools (saws and chisels) over on the OLF.
Like John said, for practice get some cheap wood from the local borg store. I
segovia
Post by segovia »
Thanks john
Do you you know the angle of the dove tail bit, a they all 7 degrees?
J
segovia
Post by segovia »
tippie53 wrote:practice with some poplar from home depot and I bet afer 3 necks you will have it down
Do you know the dovetail bit angle on the OM kits, is it 7 degrees?
J
I think they are 9
hummingbird
Post by hummingbird »
Same situation with me. I just narrowed the fretboard a bit then added bindings to make it wider. I increased it to 1.75" from 1 11/16. When sanding I just blended it in. You can't even notice the fretboard is wider than the neck at the top.
Alain
