For other than thinning properties, what do you use naptha, mineral spirits, acetone, denatured alcohol, and grandma's salve for?
Dave B
Fluids - not bodily
Re: Fluids - not bodily
I keep mineral spirits around to moisten a rag to run over wood before applying finish to make sure I don't have glue or other contaminants on the surface.
I use dna as a general cleaning solvent with my water based spray equipment, and to to dilute and clean up epoxy. Good for lots of other uses. I go through more of it than anything else you mentioned. Also great for cleaning up my wifes sink after I have made a mess of it.
Acetone is great for cleaning up ca. Keep some in a small jar and soak my ca tips in it.
