This is a simple way to get a good secure glue up of top and back plates.
The cost is pretty much free. Everything I used here was from the scrap pile. I did make use of a bench top platform I had previously built that consists of a 2x4 box with a piece of MDF on top. I use this for many things, including routing rosettes and soundholes, and many other tasks. It raises the work above the bench and gives you a clamping edge all the way around. Very convenient and easy to make.
To turn this into a plate joiner I just put a piece of waxed paper on top and clamped a piece of scrap along the right edge. I cut some small scraps of poplar into wedges.
Another scrap of pine and four c-clamps and you are ready to go. Here are some pictures
Firstly, you need to make sure your back or top plates are well jointed and ready for glue up. If you can see any light between the joint when pressed together, it's a recipe for failure. Make sure it's good and tight before you start this process.
This first picture just shows the piece of scrap pine clamped to the right edge of the MDF platform with the waxed paper on top, and the two sets of wedges sitting in place ready to go.
Here, I've clamped one of the mahogany back plates down to the base with a piece of scrap pine fairly close the jointed edge. This edge needs to be clamped securely so it doesnt slide when you apply side pressure.
This just shows the second plate with the nice glue bead ready to slide into place. Just press it firmly up against the clamped plate and apply some firm pressure by hand, and then slide the two pieces back and forth a skoche to make sure there aren't any air bubbles in the glue joint. You should see a tiny amount squeeze out bead all along the joint.
This picture shows everything in it's final place. After sliding the second plate up against the first and making sure they are tightly mated and lined up, put the second piece of pine on top of the second plate fairly close the joint and clamp it down. Don't apply too much pressure here with the clamps here. Just enough to hold the plate down against the workboard. Once you have it in place squeeze the two wedges together to apply side pressure pushing the second plate up against the first. A light tap with a small hammer to seat each set of wedges and you are done.
This shows a close up of the two wedges that are used to apply side pressure.
And here is a close up of the seam before the squeeze out is cleaned up.
This is just another picture of a completed top I joined earlier.
Once you are done, everything breaks down and goes back into the scrap pile (you might stash the wedges somewhere, but making new ones isn't a big deal).
DISCLAIMER: This is not an attempt to discredit anyone, or to suggest builders confident in their existing processes are doing it wrong. it's just another way to accomplish a task. I present this as one possible method for joining plates primarily for new builders coming along to consider. If what you are doing works for you, I would not suggest you change it.
