Carbonew Fiber Rods and Truss Rod Advice
turnertj
Hey all...
What is the going consensus about having to route and install carbon fiber rods in the neck? Is it a good thing overall, or does it make it too stiff for truss rod adjustment later? If you're using them, do you use two--one on either side of the truss rod?
Also...which truss rod are folks getting good results with? Anyone have experience with the hot rod from StewMac?
Thanks!
Tj
Thanks!
Tj
Re: Carbonew Fiber Rods and Truss Rod Advice
I don't like the hot rod . I will be honest in that CF is great at making a neck stiff , it isn't needed with a good neck and a good truss rod . I am using the same truss rod that Martin is using and find it to be as good as what it out there in 2 way rods .
I have had the Hot Rod fail and also the one from LMI. If I use CF it is rare and often used as a non adjustable rod. When I do use them I like to install them in line with the neck taper . I think this makes for a more warp resistant neck as the angle creates more of a truss effect
John,
I have used the LMI rods, and I have a Hot Rod to try this time, I'm going to put in the current guitar. What is the Martin rod? Is it the square aluminum box? Can you put up a pic?
Thanks.
Thanks.
I have a pic on my website . The old Martin rod was the Alum channel The new 2 way design is pretty stout in design. After having a hot rod fail I tested the ones I could fine , LMI Stew Mac and Martin . The weak part of the designs that failed was the silver solder of the barrel nut on the rod , The rod snapped right behind the weld as the metal was over heated and made brittle .
I tried and never got a martin rod to fail . That is why I use them . Gemini has a new design for a CF rod that is a D shape and adds a good bit of stiffness and little weight. It is non adjustable and needs compression fretting. I like the way Rick described using the CF. I have used that on older martins with the ebony neck support with success .
What is the length of that rod John?
I like the price!
I like the price!
seanbig
Here are photos of one way and two way truss rods from Blues Creek. The one way is 16", but I don't see specs for the two way. It is for a 14 fret neck, so I'd assume it's around 16" as well.
http://www.bluescreekguitars.com/shop/i ... ucts_id=26
http://www.bluescreekguitars.com/shop/i ... cts_id=128
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
Jim_H
I think the major complaint about the hotrod trussrod is that they require a fairly deep slot (7/16"), which can compromise the neck... especially if you use headstock access.
Unfortunately, I bought several of them before I knew about this. I think these will go on ebay. I'm going to stick with the LMI or Allied rods I think.
turnertj
So does anyone have a recommendation for a 12-fret truss rod? All I could find is the hot-rod specifically designed for the 12-fret. I think it measures 13".
I have used the double action 13" truss rod from LMI (http://WWW.LMII.com), for my 12 fret parlor guitars. They seem well made and are the perfect size for the 12 fret 24.9" scale guitars I make.
we do have 12 fret 2 way necks available at Blues Creek .
