Opening the dovetail mortise
Embarking on my first dovetail. What is the best way to open the mortise that is covered by the sides. On the M&T I've done I used a flush cut router bit.
Re: Opening the dovetail mortise
I am not sure what the best way is ... I used a razor saw and a chisel after I cut the binding channel.
If you have a dremel, you can use the sanding bit as well.
John and Ken, thanks that would be a good combo as I have both.
