This should be a straight forward question.
If you sand through lacquer, do you have to seal it again before putting on more lacquer?
Thanks,
Kevin Looker
Sanding Through Lacquer
klooker
Re: Sanding Through Lacquer
I really shouldn't answer this since I've not yet finished my first guitar. If the sealer isn't perfectly clear and you re-coat with lacquer and no sealer, that spot will look different than the surrounding area so may have a different tint or just reflect light differently so it stands out. So I would be afraid to.....but what do I know??? <smile>
michaeld
I recently sanded through the lacquer and sealer on maple sides (no pore filler or stain used). I resprayed the lacquer without applying any sealer. The sand-through is completely invisible and the finish looks great.
Mike
Mike
Not to worry --- the "lacquer" sealer is most likely just lacquer with more solids -- at any rate, the sand through will not show. The great thing about the nitro lacquer "systems" is that each coat is chemically compatible and they "burn-in" to form more or less a single layer. However, if you used shellac as a sealer that would have tinted the light color wood and may cause a problem. (I never use shellac for that very reason!!)
agree that your should be fine.
