I've started the finishing process of my first build - a Martin Dred kit.
First question:
How long should I let it cure before I start the final sanding/polishing?
Second question:
Isn't lacquer resistant to alcohol? I tried to clean a spot on the binding with some denatured alcohol after I sealed & sprayed a couple of coats of Deft on the back & sides. My alcohol rag rubbed against the side a little & the lacquer looked like it was starting to come off. On this rare occasion I was paying close attention so I immediately stopped. I gently dried the area then hit it lightly with a Scotch Brite & it appears ok. The lacquer had only cured for about 12 hours when this happened. Does this sound normal?
Kevin Looker
Deft Nitro Lacquer Questions
klooker
Re: Deft Nitro Lacquer Questions
lacquer takes a few weeks to cure. In most cases I find 3 weeks to allow a good cure time. Patience is one of the secrets to a good finish. It is not normal for alcohol to affect lacquer but within 12 hours the lacquer may be reacting to the water in the alcohol.
Nitro Lacquer is only alcohol "resistant" not alcohol "proof" ---- as a matter of fact lacquer thinner contains methanol --- AKA - alcohol. So even after curing alcohol can etch and soften the surface. Naphtha is better choice for clean-up.
