I'm getting close to start the finishing process on my Martin kit.
Are there any known issues with using Scotch Brite pads when doing light in between coats sanding with lacquer? I know that steel wool is bad because there are rust inhibitors that can affect the finish.
I like using the Scotch Brites because I find it easier to control them when sanding contoured surfaces as opposed to sandpaper.
Thanks,
Kevin Looker
Using Scotch Brite Pads
klooker
Re: Using Scotch Brite Pads
If you spray a coat within an hour or so , you don't need to scuff , the thinner will melt one coat into the next. I also use the scotch pads, ( maroon ).
