Maple Fretboard & Bridge Question
mjmeehan
I've never seen any variety of maple as a fretboard or bridge on an acoustic guitar. It's even difficult to find maple in a bridge blank. Is it a matter of aesthetics (light colored wood where we're used to seeing dark) or is there another reason?
Re: Maple Fretboard & Bridge Question
Maple finger-boards are coated with a heavy Epoxy finish otherwise body oils and bronze tarnish stains causing a pretty ugly black/green mess. The tarnish residue mostly likely will stain a bridge as well. I believe the "Reranch" guitar refinishing website shows how to protect the finger-board.
Jim_H
I put maple bindings on the fretboard of my first guitar, and promise I will never do it again (at least not on one I'm building for me). It's just too hard to keep clean unless it's under a bunch of finish.
mjmeehan
Thanks for the info. I can see where an acoustic fretboard all slathered up like a telecaster's would be unappealing. At least to me.
Maple and a few other light woods are often dyed black or EBONIZED to be used for fretboards . With ebony getting harder to come by it isn't a bad idea to look for alternatives before you have to use other woods.
Back on the old acoustic guitar forums, I raised this question as well. The pros couldn't understand why I would use maple for a bridge, until I explained I wanted to make either an all padauk guitar, or an all wenge guitar. Either would use maple bindings, and I wanted to tie the binding and the maple together. Set them back for a few minutes, but the reaction was "Never even thought of matchning things up that way....try it and let us know....don't see why it wouldn't work". Still haven't done it, but would like too.
First off there are many different maples. I would suspect you will be using Rock maple or another specie of hard maple. Most maples are a bit softer for bridges and you will have some dampening effect . Be sure you select the right one . Also be carefull of grain .
Yeah, I would orient the grain about 45 degrees from both the nut slot and the vertical, or something close to that.
