Mohawk rattle can
Mohawk rattle can
Post by   »
Mohawk Perfect Blend aerosol
Has anyone here used this stuff? Comments? Experiences?
http://www.mohawk-finishing.com/catalog ... ictNbr=703
"A premium blended nitrocellulose lacquer displaying excellent adhesion over waxed and polished surfaces and areas contaminated with silicone. Perfect Blend™ features a soft spray, low film build, and fine atomization resulting in virtually no overspray, little bounce, excellent flow, and strong ability to blend in with the surrounding surface."
tb
Re: Mohawk rattle can
Post by kencierp »
I believe Mohawk and Behlens Jet Spray are the same product.
Jim_H
Post by Jim_H »
brian wrote:I use this product from Mohawk and it has been excellent.
http://www.mohawk-finishing.com/catalog ... ictNbr=439
I buy it by the case from Klingspors Woodworking shop.
They also have good pricing on bulk abrasives
http://www.woodworkingshop.com/cgi-bin/ ... %20AEROSOL
Brian
Brian,
What are you using for a pore filler with this? What is your general schedule?
I'm going to be building some prototype guitars (I hope) and need an inexpensive/quick finish option for them.
j
Post by kencierp »
Watco Nitro Lacquer from the Rustoleum folks is now my "go to" aerosol, it covers great, drys a little harder than Deft (it seems) and levels and polishes out well. I use "Hood" Clear quick drying Lacquer based pore filler. $.02
I use mowhawk and Jet as that is at Grizzly and I can go there as it is about an hour away from me and that saves me the hazmat fees. I also stopped using shellac as a sealer on lacquer years ago. All shellac sealed guitars craze cracked. The vinyl sealed ones are fine .
Post by kencierp »
Ditto John on the shellac! Plus it tints, and that tint can have different values if not sanded evenly --- over time that turns to shading and can end up looking like crap several years down the road. I much prefer modern finishes, but in comparison to the large finishing shops I'm in the dark ages - UV cure polyester is now the finish of choice. Pre-cat nitro Lacquer is a close second --- vinyl sealer is also the way to go. I know! I know! -- French polish is all shellac -- that too will tint and shade, not to mention chip and craze -- but it is easy to fix.
