Thinning White Glue?
Can you thin white glue (lmi/TB) and flow it into a rosette? I've read about using fish glue this way but don't have any on me.
I think I'm starting to develop a reaction to CA and want to avoid it - otherwise I'd use that in this instance. Used it earlier today and just want to throw the stuff out. :(
Re: Thinning White Glue?
Post by   »
From the Titebond website:
"Can Titebond Wood Glues be thinned?
Most of our wood glues can be thinned with water up to 5% by weight or by volume. Adding more than 5% water to our glues will decrease the bond strength. Titebond Liquid Hide Glue is thinned by gently heating the bottle in a pan of warm water. Titebond Polyurethane Glue may only be thinned by placing the bottle into a pan of warm water. "
tb
I have been doing this a long time . If you want to wick glue into the rosette , you may want to think about fish or Hot Hide glue. On wood rosettes , if they are simple ring rosettes straight wood glue should be fine.
I have used DUCO cement and HHG succesfully . Tite bond works for single rosettes but when you get segmented ones duco is the better glue.
Avoid CA on spruce , it will turn yellow .
Post by kencierp »
I prefer Duco over PVA because it does not have water which distorts the rosette channels -- more water??
I agree with ken Duco is the best for rosettes but I will use tite done on pearl rosettes when I use teflon for the pearl channel.
Hmmm yes perhaps not the best solution "more water". I clearly need to rethink my rosette operation. Time for a more accurate cutter and to start using a different glue. This one was definitely pushing my skill/tools. Next time round...
Thanks for the input.
Jim_H
Post by Jim_H »
Curious about this.
If you thin white/yellow glue, won't it soak into the wood or purfling, dulling it's appearance under the finish?
it can
Post by kencierp »
Glue stains can be a huge finishing problem only discovered far into the process -- to that end I use the florescent Titebond -- the same stuff used at the Taylor factory. A black light reveals a glue mess instantly -- more sanding usually the cure. Not sure if this glue is available in smaller then the 32oz. size.
