New Skin / Style
seanbig
New Skin / Style
The forum now has a WoodTone skin. If you would rather revert back to the blue scheme, you can do this by doing the following:
1. Click User Control Panel - Top Right
2. Click Board Preferences - Under Options on left
3. Select subsilver2 - To the right of "My board style"
4. Press submit
There is also an option for prosilver which is another standard skin from phpBB.
4. Press submit
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
rgogo65
Re: NEW FORUM UP AND RUNNING
It looks fine. However, I find the lettering in the darker brown areas very hard to read. (Such as this post).. I would be surprised if I were the only one. It's something you may want to think about.
I found the options and reset it for my vision! Great feature..
seanbig
Re: New Skin / Style
rgogo65,
Thanks for the heads up. I will see if I can get some better contrasting colours for the darker sections.
Sean
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
JJDonohue
Yes...I also changed to the blue because the brown was too hard on these tired eyes.
me too, just changed to the blue/silver. But I like the brown/yellow...just see if you can eliminate the dark area for posted messages.
seanbig
Kevin and Others,
I recently lightened up the brown a bit. I still need to change some images that are too dark that I can't change until later tonight. Let me know if the lighter brown has helped out with visibility.
Thanks,
Sean
Thanks,
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
JRHall
I'm using the wood tone, and it looks pretty good to me.
That is better, but perhaps if the font color is black, it will show up even better.
seanbig
Yes, I like that idea Kevin, did you set yours to black, it shows up much better?Kevin Sjostrand wrote:That is better, but perhaps if the font color is black, it will show up even better.
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
seanbig
Kevin,
I took your advice with the black text. I think it helped out a lot. There are still some things that show up dark on dark that I need to take care of, but for the most part I think we've got a lot more contrast.
Sean
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
