Close to fInishing my first build
I could not wait any longer. I finished the nut and put the strings on. It sounds good. The height of the strings at the 12 fret is perfect.
This message has been posted from pMachine.You can read the old posts in the pMachine forum: http://www.KitGuitarsForum.com/forum/th ... 70_0_9_0_C
Post by naccoachbob »
Very nicely done. Salut!I had thought about stringing mine up once I put on the last clear coat on my 1st, but somehow refrained until it was cured. Gawd, I hated that wait.Might succumb to temptation on my next.How'd you like the French Polish? Is it shiny or satin?Bob
Re: Close to fInishing my first build
sweet
Thanks,
I liked using the French polish process. It took awhile but as I am doing this as a hobby, that is sort of the point. It was fun going to the web for info and viewing videos of the process. There were two camps for filling with pumice: one just alcohol and pumice, no shellac and never put pumice directly on the guitar and avoid those silly pumice bags. The other, use shellac, use the silly bags to dust the powder on the area your work. I tried both. I spent hours on the no shellac in the mumeca way with little to show for it. I really tried to mix up the variables to solve the lack of progress. (Too much alcohol washing out the fill, working to much in one area, not enough, maybe a thicker seal coat of shellac …) After a really long time I had about a quarter of the back mostly filled. I tried the shellac way (1 lb cut with extra alcohol on the muneca) with the silly pumice bags. I had half of the back filled nicely in about a half an hour. I sanded the whole back down, as the two different methods had slightly but noticeable differences and refilled with the shellac and pumice method. I did follow the instructions from Millburn guitars for the rest of the process as their tutorial is very well put together.
The two areas that were hard for me as a first timer were dealing with straight edges (the top\fret board joint and cleanup work near the bridge) and knowing when to stop. To deal with the straight edges I finally came up with taking the cover off my muneca, just after I loaded it, and wrapping it on the edge of a felt sanding block. I decided I was finished after many sessions of glazing when I realized that I was putting as many slight surface flaws on the guitar as I was taking off.
Nice!!! But honestly, you have to post more pictures than that! <smile>
