English Walnut
Species, bending tips, filling tips, experience with less common tonewoods, native substitutes for tropical hardwoods, milling, etc.
English Walnut
Post by Stray Feathers »
I belong to a woodworkers guild which mills donated logs (much of it backyard trees taken down and donated) and sells it to members at very good prices. They get a fair bit of what I think must be English Walnut, grown for the edible nuts. I have read one opinion in Tonewood Data Source that it is good tonewood, but not much more. Does anyone have any experience with it, especially to compare it with Black Walnut? Janka is higher in English Walnut which might make a difference. Bruce W.
Re: English Walnut
Post by phavriluk »
My opinion: back-and-side wood species have way less influence over acoustic performance than how thick the wood is, the size of the guitar, and how its was braced. It'll all sound like a guitar and I'd love to see documented proof of claims that this guitar sounds as it does because of the back-and-side species.
If you like the looks of a selection of wood, use it in good health knowing that it'll work just fine.
bftobin
Re: English Walnut
Post by bftobin »
First: While at Sergei De Jonge school, he stated that it really doesn't make much difference what the B&S are. He's been building with all kinds of wood since the 1960s. He once built a guitar entirely from spruce. Basically, most softer woods will be like Mahogany, and harder woods will be like Rosewoods. Secondly: It depended on internal dampening. Some woods dampen vibrations more than others. This is why 90% of the time, Ebony is better for fingerboards and Rosewoods are better for bridges.
Brent
Re: English Walnut
Many people claim it does not make much difference, but then, you say certain woods are more like mahogany, others more like rosewood. So there must be an audible difference? I can see that some woods are very similar, like different species of walnut, and I may be splitting hairs, just looking for tips when I get this walnut in my shop and dry enough to work with. Bruce W.
jread
Re: English Walnut
Post by jread »
I didn't have any experience playing nicely made guitars until I started building but here's my opinion after building 30 of them with several different tone woods. I "feel" there is generally a tonal difference between my rosewood and mahogany guitars. The two groups of guitars seem to have separate tonal qualities. A harder tap to rosewood with interesting overtones, almost a drone, or piano-like bell sound that feel different and unique from a softer mahogany with more woody, open tones.
However, I think I'd be hard pressed to pass a blind test with the instruments that built and play every day. In the end, It's all about the player. Good players can make guitars sound 1000x better than I can no matter their build quality or materials. Whether there are quantifiable and more importantly, repeatable tonal differences in wood species I think is up for serious debate.
Re: English Walnut
Good players can make guitars sound 1000x better than I can no matter their build quality or materials...
Amen to that!
FWIW, I can't detect much of a difference in sound no matter what wood gets used. Let me back up just a bit: I can hear differences in the sounds of different guitars, but i have no idea how much is attributable to the type of wood used to build it and how much is attributable to them just being a different guitar, built by somebody else, probably different strings, maybe a different-sized body...who knows?
Re: English Walnut
when you get into the science of the guitar, the top is 90% of the energy transference. The major influences of the back and sides are what I call reflective tone.
I think there is a bit of wood interaction but when it comes down to it , in a blind study often your opinions prove to be just that.
With guitars its all subjective data with limited numerical data. In voicing tops we all have our thoughts and opinions but you need to understand that the top drives the air. So the Hemholtz frequency of the box comes into play , and this is where I find that reflective input of the back and side AND THE BRACE scheme.
There has been a lot of experiments done , I think it was Rameiz , but I may be wrong , that built a back and sides set of paper mache, Taylor , martin and many production companies did make guitars out of pallet wood.
So once you understand how that top works and how the body Hemoltz frequency works with the top you will find that sound you are looking for.
Brian Gallop has many great videos on top voicing.
so welcome to the deep dark hole of tone
Stay well all
starbuc2
Re: English Walnut
Post by starbuc2 »
Hi John,
FYI, the well known cardboard guitar was by Antonio Torres in 1862. It was restored by the Yague brothers in Barcelona some years back. A recording of it being played is on the CD included in the book "Masterpieces of Guitar Making" by Grondona/Waldner. The sound it gets is more similar to the maple and cypress guitars although hard to tell those from the rosewood guitars also played on the CD.
-David
