Source for Laminated Side Wood
scamp
Post by scamp »
I’m trying to find a source for B grade/relatively inexpensive rosewood or some other appropriate wood I can use for the inside layer of laminated guitar sides I want to make. Ideally looking for something that can be sanded down to about 2mm. Can live with something thinner and possibly do multiple layers. Any help appreciated.
carld05
Re: Source for Laminated Side Wood
Post by carld05 »
I to like Exoticwoodzone great people also Hibdon Hardwood
scamp
Post by scamp »
Thanks for the suggestions. Very helpful. Now on to deciding how to do the lamination glue up. Probably just use the mold sides bolted together and a flexible caul an a lot of clamps. Too bad the vacuum pump method is so expensive. Would love to try that out.
carld05
Post by carld05 »
That's how I did it. bolted the spreaders together too and used a piece of formica to spread the clamping force evenly.
Jhunt
Post by Jhunt »
The two sources of side laminate that I am aware of are:
JS bogdanovich and Maderas Barber. The latter ships from Europe which is expensive for me (based in the US).
-James
Jhunt
Post by Jhunt »
scamp wrote: Wed Jan 01, 2025 10:30 pm Thanks for the suggestions. Very helpful. Now on to deciding how to do the lamination glue up. Probably just use the mold sides bolted together and a flexible caul an a lot of clamps. Too bad the vacuum pump method is so expensive. Would love to try that out.
If you want to try the vacuum method, but don’t want to buy an electric vacuum pump, you can get a hand pump from roarockit. Robbie O’Brien has a video demonstrating how it works.
