solid mahogany linings over kerfed
Im doing solid Mahogany linings for the cedar top of my first Gibson L-00.
Is there a rule of thumb for the width of the linings (Kerfed or solid) + the thickness of the sides?
The dimension of the purfling and binding are 3.5mm+\-
How much lining should be left after routing for the binding\purfling?
Guessing 2x 3.5mm+\-?
Mike
Mike
Re: solid mahogany linings over kerfed
Kerfing, solid or otherwise, is usually around 1/4" wide by itself. Unless you're going to use extra wide perfling as well as bindings, this is more than enough. 1/4" kerfing, plus a side width of ~ 0.090 = a little more than 8.5mm, so you're just fine with the standard 1/4" width.
I use 3 layers of mahogany from some sides I got with blems. They get thinned to about .06" or .07" and ripped to three different widths 1/2", 5/8" and 3/4". The 3/4" layer is glued in first between side supports of 1/2".
If you're using wide purfling like herringbone or abalone with other purfling outlines then you can add more layers as needed, DAMHIKT!
Then the 5/8" and 1/2" strips layered on top.
.If you're using wide purfling like herringbone or abalone with other purfling outlines then you can add more layers as needed, DAMHIKT!
Thankyou Diane .....for that info. the solid lining is measuring right at 1/4 +\-Diane Kauffmds wrote: ↑Mon Jun 10, 2024 6:19 pm Kerfing, solid or otherwise, is usually around 1/4" wide by itself. Unless you're going to use extra wide perfling as well as bindings, this is more than enough. 1/4" kerfing, plus a side width of ~ 0.090 = a little more than 8.5mm, so you're just fine with the standard 1/4" width.
Im about .085 for the sides as I could not tell the Mahogany species.
All I knew was it was old growth and it bent very easily with just minimal buckling (not sure what else to call it.)
Hey Carld...I also used the Mahoany from my test bends which went easily\well. for me...much cleaner over kerfed lining as well. my purfling-binding winds up being about 1/2 of what gets routed and the other 1/2 left for the top and or back..carld05 wrote: ↑Tue Jun 11, 2024 2:51 pm I use 3 layers of mahogany from some sides I got with blems. They get thinned to about .06" or .07" and ripped to three different widths 1/2", 5/8" and 3/4". The 3/4" layer is glued in first between side supports of 1/2". IMG_20240327_153902495_HDR.jpg
IMG_20240327_160725480.jpgIMG_20240328_160402442.jpg.
A bit of research also stated additional tonal qualities coming thru because of the solid lining for which I was hoping in this parlor guitar. Thanks for the pics...looks good.
Whats the magic to embed pics. I would like to be able to do that as well?
Barkman-Mike
Down at the bottom of the "Post a reply" screen, click on "Attachments". The instructions are there with an "Add files" button. When you get one loaded in that box, get the cursor blinking where you want the attachment in your text and click the "Place inline" button and Bob's your Uncle!
I don't think here is any research that definitively shows that solid linings are better, or worse than, kerfed linings. If there was, there would be a rush to change over to them. I think it is mostly personal preference.Kerfed lining is very easy to make, and if you make it in batches of what you will need for a year or so, making them does not take much time. I like the look of kerfed lining and to me they help make the guitar look finished. Kerfed lining is also much easier to install than solid lining. I buy into the concept of light weight instruments, so kerfed lining is also lighter, although by a very small amount. In general, kerfed lining, unless you are a slovenly builder of which I'm usure there are none of here, looks cleaner to me that either solid lining or laminated lining. Just my point of view.-Bob
Then there is reverse kerfing, which happens to be my favoriite because it adds an amazing amount of stiffness to the construction. To me, that seems likea good thing, though I have zero reasons for thinking so.
lining , whether solid or kerfed are there simply to create a glue surface contact for the tops and backs. One is as good as the other . The reverse lining is best for free building and that sets the sides onto shape .
