Couple more tenors
Couple more tenors
I have two more tenor ukuleles started. The first was started some time ago, but shelved because I broke the Ovangkol sides in the bender. I finally got organized and found some wood to cut replacement sides out of. It's a little lighter than the original back but will be okay I think.You can see the cracks in the original sides at the top of the photo. The top is Western Redcedar.
The second one is number 9 and is Australian Blackwood. I had bought some nice spruce guitar tops, and a couple were big enough only for small guitars. This one had some bearclaw figure along the centre seam so I decided to use it for this ukulele. The neck was roughed out previously for the ill-fated Ovangkol uke, but will now go on this one, since it is further along and I want to finish it for a big art event in town in August. We'll see . . . Bruce W.
Re: Couple more tenors
Nice
Looks like a tiny OM
Progress on this while also working on a 00 guitar. After a cool spring I am finally able to get outside to spray. I've just done two sealer coats on the Blackwood uke. The Ovangkol uke is set aside again. I am not happy with the side bending, which I have been doing using my Fox bender modified for ukes. The 34" blanket and slats are too unwieldy. So I have found a 24" blanket, and have ordered 24" slats from John Hall, and will try rebending the sides when I get the new bits. Bruce W.
Lookin' good!
You'll likely be very pleased with John's 24" blanket and slats. I've built my benders around these, one for tenors and an entirely separate one for concerts. Having done lots of ukes with a guitar sized bender and interchangeable bending patterns, I find the smaller, dedicated benders to be a better match for my work flow.
Blankets need a heat sink. Using long blankets that hang free of the bender can cause delamination of the blanket.Best to use the right size blanket.- Bob
Bob, I've always been concerned about the heat sink issue. I've never used a blanket longer than the slats, and even put sacrificial bits of side wood in a sandwich where the sides were shorter than the blanket and slats (maybe overkill). But I received 24" slats from John a while back, and recently got the 24" blanket from a Canadian supplier (US made) which just needs a plug, and I can rebend the Ovangkol tenor sides that just didn't come out right with the guitar-length blanket and slats. Next step (in my spare time . . .) might be a dedicated ukulele side bender. Bruce W.
Where does the time go? I finished one of these ukuleles in the summer and never posted photos. This is the Aussie Blackwood uke, with Engelmann Spruce top, with some bearclaw you might make out mostly along the centre seam. I find bearclaw in Engelmann to be a little more elegant, as opposed to the coarser bearclaw in Sitka. This one sounds good, but I don't see enough commercial ukes to do comparisons. Bruce W.
And an update on the long-suffering Ovangkol tenor: The body is finally done and looks okay. I elected to try the ebony end flash without mitred purflings, but I am not crazy about it. I have used Western Redcedar on a couple of other tenors, and I am curious to see how this sounds since I have been trying to lighten my bracing. I have a neck partly done, which I squeezed out of a Khaya piece after I cut two guitar neck blanks out of it. I'll finish this one in time for outdoor spraying in early summer. Bruce W.
A bit of an update after a long gap: Here are photos of the Ovangkol/Redcedar uke finally in the finishing process. And a new tenor uke I have made from a billet of Sitka I have used before, and some more of the Sweet Cherry that came from a tree in our yard. I have been pleasantly surprised by two earlier Sweet Cherry tenors, so I am interested to see if I can isolate the cherry as what made the others sound so sweet. These have ten coats of lacquer, more to come, and no levelling or drop filling yet. These are going in a street art festival in August, and a handmade instrument show in October. Bruce W.
Bruce those a purty purty.
