new steam needle for pulling necks
tried the heat cartridge THEY SUCK
too large a hole
used the stew mac needle for years but I found this
https://www.mscdirect.com/product/detai ... lsrc=aw.ds
you can make your own steam needles
Re: new steam needle for pulling necks
Post by phavriluk »
The link brought me to a listing for 1/16" stainless steel rod. Eh?
Bob Gleason
Post by Bob Gleason »
Hard to beat the age old basketball filling needle with the end cut off above the air holes. Cheap, available locally, needs only a reasonable size hole, and the threaded end fits nicely into surgical tubing that also fits nicely on the steam vent from a yard sale espresso maker or the second choice jury rigged to a tea kettle.
I found the 1/16 tubing allows for deeper penetration but without having to create work in fixing the hole everything hide under the fret I think I need to make a video on this
I have the solid rod and I totally agree. It sucks rotten eggs! The hole you have to make is HUGE.
This is what I use. It's long, so I cut it in half, leaving a reserve tube. I bought this 4 years ago and I'm still using it.
uxcell 304 Stainless Steel Round Tubing 2mm OD 0.3mm Wall Thickness 250mm Length Seamless Straight Pipe Tube https://a.co/d/4wDtENR
