Build #2: StewMac Mahogany Dreadnought
rcnewcomb
Re: Build #2: StewMac Mahogany Dreadnought
With the help of Kathy Matsushita I was able to make some more progress. Here I am sanding the top radius into the bridge. Note the sandpaper taped to the top.
- Randall Newcomb
rcnewcomb
Tape markings to ensure the neck lines up with the centerline
- Randall Newcomb
rcnewcomb
Stripping the finish where the fingerboard extension will be glued on, then drying the area before gluing.
- Randall Newcomb
rcnewcomb
Gluing on the neck. The sound port on the side is handy for photos. I'm grateful for Kathy's help.
- Randall Newcomb
rcnewcomb
Another view from the inside
- Randall Newcomb
rcnewcomb
Trying a new tool for placing the bridge.
- Randall Newcomb
rcnewcomb
Placing the bridge and marking with tape
- Randall Newcomb
rcnewcomb
Masking the body since I am going to use stripper to remove the shellac where the bridge will be glued on.
- Randall Newcomb
rcnewcomb
Stripping the finish where the bridge will go, before and after:
- Randall Newcomb
rcnewcomb
Gluing the bridge. I still ended up with a tiny bit of blue tape under the bridge.
- Randall Newcomb
