A more-or-less copy of a Martin OM
Re: I glued in the bridge plate...I hope it's okay
MaineGeezer wrote:This afternoon I glued in the bridge plate I carved out out a piece of maple firewood. Cutting a flat piece of wood 0.10" thick out of a random log is a lot of work! I split off a slab as a starting point so it would be quartered and have perpendicular grain. That part worked quite well.
Carter curves the back and front of his bridge plates; based on what he's seen doing repair work, he believes a straight back or front edge on a bridge plate acts as a stress concentrator and becomes a line of weakness. Curving those edges better distributes the forces, or at least that's the theory. Sounds good to me....
My bridge plate is larger than most that I've seen. I hope it's not too large!
I put a larger than usual plate on my project guitar and it sounds great. It makes me wonder if a larger bridge plate conducts the vibrations from the strings more efficiently.
I love the look of the bridge plate.
Top is done, at least mostly; braces glued to the back
Today I brought the top braces down to final dimensions, with Carter's supervision and explanation of what to listen for when tapped. I may sand them a bit more to clean up the appearance, and clean off the glue ooze-out with Zip-Strip. My 3rd attempt at a bridge plate was approved.
I also glued the braces on the back and started shaping them with a chisel and block plane. The back will have a 12' radius -- Carter has a preference for somewhat more curvature than many builders do. His theory is, when the wood expands and contacts, the curvature gives the movement a place to go. His guitars sound extremely good, so the curvature certainly doesn't hurt the sound any.
Re: A more-or-less copy of a Martin OM
Looking good Steve. You're guitar "guru" has some interesting ideas that I may incorporate into my next guitar.
Rowrbazzle....
The back has warped. The back braces have warped. Instead of the 12' convex radius I cut into the braces, it's a slightly concave radius -- it's warped so much it's gone past flat and is curving the other way.
So what do I do about that? I assume it's due to uncontrolled humidity changes before, during, and after assembly. First step is probably to get it into a controlled 50% humidity space and see what happens to it.
Yep, humidity.
Put a hair dryer to it, on the concave side and see if it starts to move, then put it in a place with lower than 50% humidity for a few days.
The problem isn't too much moisture -- it's too little. With a wood fire going 24-7, the house gets really dry. I've been humidifying it, and it's gotten better. It still has a way to go.
Tail wedge installed
Some more visible progress. The end blocks are glued to the sides, and the tail wedge installed. It's another piece of quartersawn dogwood that echoes the headstock cap.
The end pin
I just made the end pin out of dogwood to match the bridge pins. I hope I go the taper correct.
Gosh, your end pin looks so nice! So does your end wedge.
Isn't it amazing how the lack of humidity affects guitars so quickly? It takes a very short time to do real damage to an acoustic guitar when the air is dry. The addition of humidity fixes things quickly. I started seeing small changes in the OM while I was building it, that indicated it was drying out. I started storing the box in the guitar case with the Oasis humidifier, while I was building, which stabilized it.
I'm obsessive compulsive about guitar humidity.
As soon as I get the back and top glued to the sides and trimmed so they will fit the guitar case, I'll be storing the in-progress guitar in the case with a humidifier too.
