Guitar #3 -- an OM cutaway
Re: Guitar #3 -- an OM cutaway
Gorgeous wood there!
I got it from Tom Thiel in Center Sandwich, NH. Iit looks even better now, with more finish on it. I hope I can do it justice.
I got the kerfing glued on the top edges of the sides and sanded to a 25' radius. Next step will be to put on the side braces.
John J
Post by John J »
Looking good. I tend to glue the side braces before top or back goes on for ease of clamping.
Learning every day.
Good thought. That would be the logical sequence.
Gluing in the tail wedge
This should have been done before I glued the back, too.
John J
Post by John J »
Live and learn. This weekend I glued in the x braces before routing and installing the rosette. Made for a challenge ;-)
Learning every day.
Yes, that would make life more difficult than it really needs to be!
The wedge came out quite nicely. The hole for the end pin (it will be a pickup jack, hence the 1/2" hole) is centered and everything. I began to think things were going well. I should never do that! I then proceeded to mangle the notch in the X brace. I need to get a couple more strips and try again.
John J
Post by John J »
I like the contrast of the dark wedge against the lighter sides.
Learning every day.
Gluing on the top braces
Those of you in snow country will undoubtedly recognize the rods I'm using as go-bar rods. (Maybe they are available in non-snow areas too.) If you're unfamiliar with them, they're fiberglass rods about 4' long used to mark the edges of driveways, sidewalks, and such. They are pretty cheap -- $2 or so apiece -- and work well as go-bar rods. They happen to be just the right length to fit between my bench top and the ceiling.
The wood strips I'm also using are hickory.
