M&T (bolt-on) Neck Angle
Re: M&T (bolt-on) Neck Angle
I agree that is a very nice looking guitar. The neck looks good; I am not sure how it would be to play. a lot of gutairs have a wider ledge. I would not change the neck.
I do not have enough experience to say if the slot angle is OK as it is. Maybe you can widen the slot to change the angle. I like a wider saddle as it gives me more room for intonation.
I agree, no problem with the ledge...many have them, even wider. Personally, I try to blend it in, but that's after making a couple where I forgot too;). As far as the saddle slot, some make them tipped, but I don't know the angle. I don't think it looks too bad, though it might be more aggressively angled than I have seen. Worst case....try it out! If it doesn't work out, the slot can be re-routed for a larger saddle. I use 3/8" unbleached saddles, I like the look, they give me more room for compensation, and they are the ultimate cool. (jk)
I too think your neck is just fine. I think Taylor cutaways have a bit of of the binding sticking out. I can tell you cause my last build was a cutaway dred, it is hard to make that transition flush...body to fretboard. I accomplished it, but with a lot of sweat and dry fitting and sanding before the binding ever was put on the body.
The angle on the bridge looks a bit steep to me. It will give you more break angle maybe, but I would think there will be more pressure against the front of the saddle slot then down against the bottom of the slot, and cause a problem down the road....just wondering.
Your guitar does look nice, good job so far.
Thanx all for the replies & your positive thoughts about the overhang.
Needless to say, it would have drove me nuts every time I picked it up. Over the weekend I switched the neck out for another one I had. The two are very similar, except the new one is Mahogany w/ a volute. The other Spanish Cedar. The biggest reason was I prefer a 1 3/4" nut width & that's why the orig one came up shy! I had to plane the Ebony board down for binding, inlay the side dots, & epoxy the TR, drill for tuners, & glue-up the fretboard for it to be done. It fits & lines up far better than the first neck. Ironically, the former neck, fits great on another rimset I have that also has a cutaway. So, all is good & I was a busy boy all weekend and then some...
Also: The bridge I had shown earlier has been replaced as well. It had too much angle & looked awkward imo and possibly would have led to a problem. The new bridge had no diamond inlays on the wings & I wanted to have it match the fretboard inlays. After watching John's YT videos on 'Inlays', I got up the courage to have a go at my 1st attempt doing inlay. Thanks Johnnparchem for the tip on using 'white glue' to temporarily them down. I left mine on overnite & it broke trying to get it off...lol, but it mended easily. Not sure if the new one is Ebony or Rwd, but it sure is dark...Macassar Ebony maybe ? In all, not as difficult as I thought it would be. Now, I'm thinking torch inlay for the hdstk. :>) Thank you John H for all your help...!
That is a beautiful looking guitar. I am glad you are ending up with a guitar without compromise.
btw... I only leave the inlay on for about 15 minutes max. Just enough time to have the glue get tacky and for me to scribe around the inlay :)
Post by JVan »
You have a really nice looking guitar there! Keep it up. I like the your new bridge, I like the smaller diamonds on the ebony , very classy!
nice work and nice photos
It sure looks like you got that fretboard flush with the side.....good job.
...a little closer!
I've been working on the finishing aspect of this build. Spraying lacquer on the neck & body. I also felt the hdstk needed something since I've not come up w/ a logo of sorts just yet. So, I did a variant of a torch inlay & simplified the design w/out all the dots...per the bride's request. Plus, I lost one of the teardrops trying to pry it off the cardboard.
Using sanding sealer as a wash coat (twice), I then mixed-up Bartleys med grain filler & added stains in...to color it up some. I only grain-filled one time. Next day, after lightly sanding, I shot 3 more good coats of S&S. Sanded that flat w/ 400 grit. I had to address a few areas that needed some CA to bring the level up on the backstrip, but they're ok now. All toll, after sanding in between coats, I think I put on 4 top coats, using less than 2 cans of Deft gloss lacquer. One less on the top. The hdstk was a little more problematic, seeing as I had some pits & a sand-through....more lacquer :>)
After the rule of threes, I start wet sanding w/ naphtha & a little eraser, usually w/in an hour of the last spraying session. A little unorthodox, but it works for me. I feel it off-gasses quicker this way. I heard tell that Collings Guitars does something to the same effect ~ Dunno...?
It's a matter of time now, b4 I can do a final sanding. This is where I get impatient...lol!
~ Rich
Looks real nice. Good job on the inlay.
