No. 4 - my attempt at a mahogany/sitka folk size
Re: No. 4 - my attempt at a mahogany/sitka folk size
Post by nkwak »
Update as of March 5th:
I've proceeded with the use of the neck and admit that I still need to refine the volute but with the dovetail glued and pinned/screwed back in place it sits firmly enough to be placed in a string swing:
As you can see I plugged the previous holes for the tuning machines at that time and had removed the purfling on the top. I've done some things since that I will go on to describe in following posts.
Post by nkwak »
Here's what things look like as of March 31st, 2026:
- tuning machines are back on,
- the neck is aligned along the centerline (but not the neck angle and I STILL need to refine the volute,)
- I've removed the binding and purfling from the top in order to clean up the ledges for the purfling which had been coming out because it was too shallow
- the side dots are in place (I spent a good couple of hours on it with the effort of being methodical and not rushing,) and:
- I've fretted and filed the first 14 frets (but not completely dressed them.) I am waiting until the neck is properly set so that I can finish the rest with the neck attached to the body; these were done on a cradle.
Post by nkwak »
I glued in the new binding and purfling the other day but the channel for the inner purfling ring wasn't wide enough and the strip tore out while leveling it.
Post by nkwak »
I'm learning from my mistakes and opted to try the violin purfling took instead - at least to start:
I supplemented the tool with use of an Exacto knife and a fine pointed file:
Post by nkwak »
Long story short, after using thin CA glue and carefully sanding it flush here's how the repair turned out:
From a distance it's barely noticable:
