Martin Jumbo - Rosewood Kit
Selah
Re: Martin Jumbo - Rosewood Kit
Post by Selah »
Top and back are on. I am trying out some shims to fix the neck joint problem. A couple of popsicle sticks seem to work. Should I glue the popsicle sticks to the neck part of the joint first?
I generally glue them all in when the neck is ready . So if you are done working the neck joint you may certainly glue them in. Use the neck and wax paper so you don't glue the neck in but do get the shims glued properly
I glue everything at once, but I see no reason why you couldn't glue the shims first. I think I would glue them into the pocket, not to the neck, but that is just my inclination. As John says, you have to be sure they end up in the right plaace.
Selah
Post by Selah »
Back and top are on. I’ve routed in the binding and this raised another question.
The binding is perfectly flush on the top of the back yet sticks out a little proud on the sides where the back is really arched. I have the router bit that has multiple bearings. I could go a little deeper by changing from the 0.80” bearing to the 0.780” bearing. This may make the cut a slight bit too deep. Would it be better to do that and allow for a little thickness of glue or to stay as is and sand the binding down a bit? My thinking is to go a little deeper and sand the wood down to match. The thickness of my binding is 0.065” which is half way between the 0.060” and the 0.070” thickness noted on the router bit instructions.
I think I'd leave the binding a little proud and use a scraper to take it down to be flush with the sides. The sides (ideally) should be flat vertically, not tapered inward at the top and/or bottom.
You also want to be sure the binding is of uniform thickness, of course, which implies the binding channel that you cut is of uniform depth. A little shallow is fine, as long as it is uniformly a little shallow.
I set my binding just under the sides a thou the key no matter what technique you use is not to pinch out the binding. I like to see an even reveal all around the body. The back is the hardest area. I can't stress enough about prep and execution.
Selah
Post by Selah »
I’m to the point of putting on binding and purfling. The kit came with two bigger pieces of binding, both 0.063” by 0.21” and one tiny one at 0.027” by 0.063”. One of the big pieces is the binging. The tiny piece is the purfling. What is the other bigger piece for?
Second question: the top also came with two bigger pieces with the same dimension as above. The tiny piece measures 0.070” square. Again, I assume one of the bigger pieces is the binding. For the top, I have ordered one of John’s herringbone purflings. Should I just use one of the bigger pieces for a binding and the herringbone purfling? Should I put the tiny purfling between the binding and herringbone? Does it even matter, or is it just personal preference?
Basically, in my research, it appears as if you can use any combination of binding and purfling that you desire for you guitar. Is that true? Is there some overlap benefit provided by the purfling?
S
Many guitars have been built with no binding at all, let alone purfling. It is decorative. On a violin family instrument, it is set back from the edge of the top and back which overhang the sides,and they strengthen the delicate shape of the wood, but on guitars that is not necessary.
Yes, you can assemble just about any combination you want. One limiting factor can be the width. If it is too wide, the channel will be wider than the kerfing strip. If you have a thin top or back and cut the channel a bit too deep, you may find thaat you have just cut the top or back loose. If you are careful you can install wide purfling. Just be aware of the need to leave enough thickness when you cut thechannel. A 0.050" deep channel in a 0.085" top leaves about 1/32" .
purfling was for the back and herringbone on the top
square piece is the heel cap and the tapered piece is for the tail joint
