hummingbird #2 Padauk Sapwood - Bear Claw Dred
hummingbird
Re: hummingbird #2 Padauk Sapwood - Bear Claw Dred
The inside ring was not cooperative at all. I broke the first length and the second length split apart in a nasty non reversable way as the glue melted from the heat. Also one of the glue joints in the rosette ring came apart from the heat.
Definately heat is not a good way to bend herringbone. Never again.
Alain
hummingbird
OK so heat didn't work that well...
So I tried soaking the length of herringbone in hot water (from the tap not boiling) in the laundry sink for about 10 minutes.
As the water was starting to cool off I let the hot tap water run into the plugged sink as I gently and patiently manipulated the herringbone under water. I was easily able to slowly and carefully bend it into a tight circle by hand while keeping it from twisting. Once I got it into a small circle I quickly patted it dry with a towel and placed it inside the rosette ring and let it expand into it. Then I clamped the pieces down together to dry overnight.
Im feeling quite proud of my first rosette. :-)
Alain
nice pictorial
rosette looks killer
The rosette looks very nice! Nice technique.
hummingbird
Installed my rosette today
Alain
hummingbird
Rosette inlayed and sanded nice like.
Alain
hummingbird
More pics of the bear claw top
Alain
Nice top, good job on that rosette.
Spiritbearguitars
Hi Al, you are doing some great work. I'm just sorry I'm at the other end of the country - I can't see these beauties in person.
SB
