Blogging Fatso!
Re: Blogging Fatso!
I made and lnstalled the nut.
Re: Blogging Fatso!
Post by Tony_in_NYC »
Looking good! You sure did get a nice finish on this one David! Nice and flat and shiny! I can't wait to see it finished!
Re: Blogging Fatso!
Installed the tuners last night.
Re: Blogging Fatso!
Sweet, sweet, sweet.
I agree with Tony.....
Re: Blogging Fatso!
Mounted the neck to the body this morning. I got the neck centered in relation to the body however the bridge is not perfectly centered, not sure what happened but I'm quite sure it is a result of operator error. What will be the reprocussions of this screw-up?
Re: Blogging Fatso!
That would be a YES Ken!
Re: Blogging Fatso!
put on the e strings and see where they fall on the edges of the fretboard. That is your best guide now.
Jim_H
Re: Blogging Fatso!
Post by Jim_H »
The low E strings proximity to the edge of the fretboard might cause playability issues.
Is the neck glued on?
If not, you can still make some adjustments. At this point the necks relationship to the bridge is more important than it's relationship to the center of the body.
Re: Blogging Fatso!
you did bridge to the center line of the neck and not the body right ?
Re: Blogging Fatso!
Yes John, as you can see I used Ken's bridge locating tool but one of two things happened, either I didn't get the bridge centered in the tool from the get go or it somehow moved when I was drilling the locating holes, my mistake either way! Now do I need to try to fix it and maybe mess something up worse or is it not so bad that I could just leave it as it is?
